netDbMgr process failed to assign an event structure. Event assignment failures will result in missed events and incorrect operation of netDbMgr
Check free memory available on the system using the "show memory" command. If there is sufficient memory try restarting netDbMgr. If the issue persists, on systems with backup nodes try failing over to the backup. Standalone systems may require a reboot to correct the problem.
Error
Failed to assign an event; %name%
| Name | Type |
| name | String |
